SLiWooDy
Flight distance : 126234 ft
OK I took my SmallRig Cage off to see if it balances and it does, here is the settings you need. (this is with lens Hood on)
Camera Base Plate: Set to the "heavy" (furthest setting) , and the slider stopper on the plate just touching the number 0 on the gauge. (what would be -1 mm on the plate)
Mount Base Sledge: 21mm (the mount that the camera and plate sit on. moves left and right)
Upper TILT axis measurement : 35mm (Moves up and down, righthand side of the camera)
Lower PAN axis measurement: 16mm (just above the power button, moves forwards and backwards)
This gets an excellent on the Balance test.
THIS IS WITHOUT THE RISER PLATE! (it really could do with the riser plate as the zoom ring is touching the plate, but mine is out in the garage at the minute)
Let me know how you get on, or need help with the measurements.
cheers
Woody
