Assistant 2 cannot connect to mavico Pro
206 0 2019-10-3
Plutonio
Flight distance : 15105 ft
Dear all
I'm try to use at least once, the software assitant 2.
I've installed version 2.0.8 on a W10 64 bit.
I connect the Mavic to my PC trought USB cable (i used different cables) but no any heart bit.
I try to fix it, following the thousand solution i got around the web. But no any positive result.
Which kind of additional info do you need in order to give me the best solution?
P.S. because the interface software is the weakness of DJI system (even the DJI Go 4 for android seems has a problem that i had to buy a Applce Phone to run it properly) i suggest to change the Debugging team.
2019-10-3
