Jaowstar
Sweden
Ben Mason Posted at 10-16 06:53
How far the aircraft can travel depends on your region, the drone adjusts it's settings to match the local laws. In the UK you would be limited to 500m and start to loose signal after that. I would definitely switch to the Iphone 7, i have used an IPAD Mini 2 previously with the Phantom 3's and i had similar connectivity issues. If you wan't to check the firmware version you can tap the ... in the top right of the screen while in the app and connected to your drone, then scroll all the way to the bottom and tap about, that should show you your firmware versions.
Hey Ben!
Thank's for you reply!
Oh I didn't know that distance is depending of my region! Well, I live in Sweden so.. do you know anything about it?
Alright! Then I would change to a iPhone 7 Plus I have laying around, alternatively my iPhone X that I use right now.
Thanks for the description of where I can check the firmware version!
Cheers!
/ Justine |
