DJI Assistant 2 (for Mavic) installer Catalina
123456
11672 229 2019-11-11
bwolsey
Flight distance : 250472 ft
DJI Mindy Posted at 2019-11-21 23:09
PM has been sent, please check, thanks.
Can you please send me work around. Same issue
2020-7-2
ogrossman Posted at 6-24 16:17
Could you please PM me the workaround too?
2020-7-3
markl81 Posted at 6-24 09:06
Mindy, can you pls PM the solution for getting the MAVIC PRO Platnium to connect with DJI Assistant?
Sorry for my late response, please check my PM, thanks.
2020-7-3
bwolsey Posted at 7-2 21:01
PM has been sent, please check.
2020-7-3
wakkoroti
DJI Mindy Posted at 7-3 02:04
Could I get the workaround please?
2020-7-10
wakkoroti Posted at 7-10 10:28
PM has been replied, please check it and have a try, thanks.
2020-7-10
djiuser_iR5bNwFXedDG
Hello, could I please receive the workaround as well. Thank you in advance.
2020-7-18
djiuser_iR5bNwFXedDG Posted at 7-18 08:20
Please check the PM, thanks.
2020-7-18
chris.hale.65gmail.com
Flight distance : 2391099 ft
Any update on this? I have downloaded the file mentioned and installed as instructed  and still not able to get this to connect. https://github.com/jwise/HoRNDIS/files/3719733/HoRNDIS-9.2-catalina_install.pkg.zip
2020-7-19
Shotik
Flight distance : 196073 ft
Czechia
same here, any solution ??
2020-8-10
Shotik Posted at 8-10 23:03
I've sent you PM, please check it and have a try.
2020-8-11
Dviate
Flight distance : 45069 ft
Hi @DJI Mindy, can you PM me the solution?
2020-8-17
djiuser_oV7nlVuu7pk1
DJI Mindy Posted at 2019-11-19 03:06
Hi hurstja, thanks for your patience, I have PM you the workaround, please check, thanks.
DJI Mindy: why PMs? Just post the solution.
2020-8-26
selina.zarzour
Lebanon
Hi, @DJI Mindy Could you please PM me the workaround also please, same issue.
Thanks!
2020-9-2
Dviate Posted at 8-17 11:19
Sorry for the late response. I've sent you PM, please check it and have a try.
2020-9-3
djiuser_oV7nlVuu7pk1 Posted at 8-26 07:09
2020-9-3
selina.zarzour Posted at 9-2 07:30
Thanks!
Hi there, I've sent you PM, please check it and have a try.
2020-9-3
oliver.eckel
Austria
its not working for me either, please send solution
2020-10-6
Flight distance : 294590 ft
Mexico
DJI Mindy Posted at 2019-12-11 20:14
Please check my PM, thanks.
I have the same trouble with Catalina 110.15.7. Can you help me please with DJI Assistant 2 for Phantom?
Thanks in advances
2020-11-29
oliver.eckel@gmail.com Posted at 10-6 00:17
2020-11-29
\@JmAguirreL Posted at 11-29 17:09
Thanks in advances
Hi there, I've sent you PM, please check it and have a try. Thanks.
2020-11-29
joelafrite
DJI Mindy Posted at 2019-12-24 01:16
Hi there, please check my PM, thank you.
Can I have the workaround too, please?
2020-12-21
joelafrite Posted at 12-21 18:05
2020-12-22
Alex Per
Mexico
The same issue. Send me the workaround please
2020-12-27
Alex Per Posted at 12-27 19:30
2020-12-28
OGelise
Belgium
Hi, can you send me the fix via PM ?
Thanks
2021-1-20
DJI Natalia
OGelise Posted at 1-20 11:30
Thanks
I have sent you PM, please check and have a try, thanks.
2021-1-20
hurstja
Flight distance : 43602 ft
DJI Natalia Posted at 1-20 23:09
https://joshuawise.com/horndis
The latest version available is 9.2: HoRNDIS-9.2.pkg (46919 bytes) (md5sum 8207800ef89dc1bb0cca530e4ef39009; GPG signature). Improves support for devices including Nokia 7 Plus. This release was developed by Mikhail Iakhiaev, who is the current maintainer of HoRNDIS. This version only supports MacOS 10.11 and up.
2021-1-21
DJI Natalia
hurstja Posted at 1-21 01:18
Hi there, may I know the model of your drone and the specific issue that you encountered? Thanks.
2021-1-21
hurstja
DJI Natalia Posted at 1-21 19:45
No problems, here, Natalia.
2021-1-22
123456
