m80116
Flight distance : 3264131 ft
You should post the logs rather than the screenshots if you want an appreciation based on facts, let alone screenshots in (?) Portuguese which most of us can't read or conveniently translate.
Anyway... at this point should also be rather known the fact that in spite of all odds, one of the Mini's design limitation is the air-speed sensitive height measurement. If you lower you drone with strong wind, depending on the direction it was coming from, it is possible that when the wind stops and or it is considerably reduced, the pressure reading will be altered. If the drone reads less pressure that translates into a gain of altitude, to which FC responds to throttling the power (RPM) to the motors even more.
You should always be extra careful when flying above water, not only because the VPS can be fooled or the wind variation can spoil the height measurement (through pressure reading) but also because it takes nothing for the drone to be dragged out of your control when the wind comes unmoderated from a vast expanse of water that could be a sea or a lake. |
