mycior
Flight distance : 48668 ft
Poland
Hello. I have a problem with the gimbal, namely the "Gimbal stuck" error
I don't know if it's broken or it's software fault (users say on foreign forums).
It helps to move it in different directions quite vigorously, but I have the impression that this random starting makes it work. Once I hit the wall with it, but as I mentioned earlier - users have not had any accident, and also have a problem with it.
I installed the drone software again and started working without a problem. Unfortunately, I put it down for a few minutes and put on a plastic cover. Later, I took off, started and still the gimbal will not even move + message.
I installed an older version of the software, but it's still the same.
I can already recognize when it snaps or not, namely when starting always calibrates. How it works, the top and bottom are calibrated vertically and stands still.
If it doesn't work, the vertical calibration looks like it moves up / down probably three times ...
I will add that I did the gimbal calibration (how it works) + compass calibration + something like "I".
I have DJI Care, but I don't want to send him back with such a thing ...
Have any of you had this case? On the forums they write about the same and give different advice, but they do not work for me.
VIDEO:
Gimbal (does not work): youtube.com/watch?v=yzL_37MkFSw
Gimbal work: youtube.com/watch?v=YbIhvbdpuCc |
