djiuser_MzsS84mhozyk
fans450974d6 Posted at 1-9 20:45
Same problems, received on 1/8/2020, charged, connected to controller, firmware upgrade, one short flight indoors then received the gimbal error, tried calibration multiple times using auto and manual, 10% showed initially and never changed, manual the values never changed. At start the gimbal went through several movements so seems to be functional but don’t know if there is something it isn’t doing since I haven’t seen a normal startup. My experience is iOS, is this happening to both iOS and Android? Seems reports go back several months and at least 2 versions of firmware. Where is DJI?
To all out there. I had this same problem with the gimble straight out of the box. Found a YouTube video with a solution. Get ready for this... Just slap the back of the drone just a bit more than a tap, whammo, problem fixed. I guess something just needed to be loosened on the inside. |
