dschloss
Flight distance : 22680 ft
ChRoM Posted at 12-31 05:11
When I contcted support some two hours ago, they didn't yet know that the update had been released ;-)
I wonder if the "aircraft not connedted" message is a translation issue. It doesn't really make sense to tie the licence to the controller but then check for the aircraft. I guess.
To me it does make some sense, also see how their video explains how it works with the DJI Go App:
- you request a license for a controller, so it is linked to a controller (by SerNo)
- then you use the controller for a certain drone (that has its own SerNo)
- when the drone detects that its GPS position is inside a rectricted area, it (should) check via the controller it is connected to, if there is a valid license for the restricted area
- if there is a valid license, the user shall activate an available valid license for the given drone – so it can claim and use it for flying
- if then the drone shall no longer use it, you should be able to release it from the drone, making it available for connecting it to another drone
So, the translation for a button that I am expecting to see in the UI could be:
- "Lizenz für Fluggerät aktivieren",
…and then, after activation, it could say in the separate screen of linked/activated licenses:
- "Lizenz für Fluggerät deaktivieren".
But currently there is no option available anywhere…
I was hoping to see a dialog that does that linking when trying to take off the drone…
