Dokan Creative
DJI Paladin Posted at 2019-11-19 08:29
Hi, I am sorry for the trouble your DJI Mavic Mini has caused. For the Overheating message. The Mavic Mini does not have a fan, so it uses the heat sink on the bottom of the aircraft to dissipate heat. After the aircraft is powered on and kept on a flat surface (such as ground or a desk) for a while, the heat dissipation will be affected, as the surface is close to the heat sink. In this case, the aircraft should be turned off and kept idle for a while to drop its temperature before using it again. Thank you.
Hi all! The main problem: if i would like check all setting in the DJI Fly app, i have to turn on the drone. Why? Okay, first time, when i make a main settings, is accepatble, but later is totaly unnecessary, somtime i browse the menu more than 20 minutes, because i would like to know my possibilities.
The main problem the software (DJI Fly) Why need to turning on the drone? The software exactly know my drone and it's parameters. Should be an immediatly update, because it is a kritical bug, This problem annoying tens of tousands of Mini/Mini2 users. |
