thE29
Flight distance : 14094 ft
Austria
djiuser_9nsc7gZZeEJh Posted at 5-11 09:26
Thanks. But I thought the Mi 9, Mi 9t and Mi 9SE were all slightly different phones. There's also a Mi 9 Lite, I wonder about that? If they all work then that's great.
I currently have a Samsung Galaxy A3 2017 which doesn't work with DJI Fly. I need to buy a new phone but I only want it for the MM. I like my A3 for a phone as it's small enough to fit in my pocket. So I need to find a phone for the MM which will work but which isn't too expensive! The Redmi Note 8 is on Amazon for £200, that's about my limit, but does the Redmi Note 8 work with MM?
Yeah, they are slightly different. But the most depending factor is if it is a 64bit CPU.
So even the Mi9 lite (also the SE) should be able to use the app, as it has a 64bit CPU. How good is another question, but it was also working fine on my Mi6, which is from July 2017.
I picked the Mi 9T Pro, because of no notch. I dont want any (or a punch-hole).
There should also be the Xiaomi A2 and A2 lite and even an A3. They have normal android. Without any changes. A2 being older. All have 64bit CPUs.
