2 versions mavic mini hardware
12
25150 56 2019-11-26
djiuser_Z1en2IPx9Xdw
InspektorGadjet Posted at 2019-11-26 07:42
Those are different sides of the PCB it would be interesting to see both sides in both versions.
Very true i heard about this on youtube
2020-4-5
deeexit
Slovenia
Hi guys. I'm new here, but not really new in embedded design. I've got my Mini a while back and since it is CE version I started to wonder what the differences are. I see you already did admirable work providing motherboards from both versions. Since it seems there are only 5.8GHz amps missing, it might be easier to mod with right parts. If you look at the mini specs you see that the advertised output power for 5.8GHz of CE version is the same as Atheros part, so meaning no amps connected to the RF output.
There might also be another path with adding external amplifiers, but I am yet to understand the basics of RF transmission here as providing amplified RF output still doesn't solve the needed sensitivity of the receiving part which datasheet states around -71. Since we can't really influence this part of the chip, we might try with better antennas? I've seen mini lift over 150g of cargo, so adding a few more grams might not affect overall characteristics. It seems there is much to do in the drone world...
Have fun guys and fly safe!
2020-7-20
22340179
Flight distance : 6763835 ft
They learnt from their previous drones they can't simply use software to enable restrictions. Drones like the Mavic Air were easy to spoof location to enable fcc mode. It has more to do with having to comply with local regulations than anything sinister. It's easier for them to make one drone and just software mods, but it didn't work well in the past so they had to make it hardware/firmware based.
2020-7-20
Skydiver021
Serbia
HedgeTrimmer Posted at 1-13 04:44
There are other missing components in FCC vs CE combined picture.
For example: Two small chips missing in upper left corner of CE version below top red circle.
Yes and also smaller parts like smd resistors and capatisors.
2020-7-20
HedgeTrimmer
Skydiver021 Posted at 7-20 13:01
Gone are days when you could look at a component and know it was resistor, capacitor, inductor, diode, transistor, or a chip which had a part # you could cross reference.  Along with color codes giving you ohms, uH, or pF.
2020-7-20
deeexit
Slovenia
22340179 Posted at 7-20 12:50
That is understood. But still, adding your own RF amplifier should work. Id also love to get a hold of their command system so I can make a proper ground station without the controller.
2020-7-20
rodolfo.mendezbol.com.br
Brazil
uma pergunta? o rádio controle nao é diferente também pois uma placa e 2.4ghz e a outra 5ghz?
2020-9-18
zufanur-wolf
Indonesia
where i can buy by online, is ready stock?
2020-10-27
Flaming
Flight distance : 250541 ft
not only the chips .... there is at least 32 capacitor/resistor missing on the CE version ....
same PCB but populated very diffrently on both side ...  from what i see .. you can all forget the idea to transform a CE board into FCC  if this is the plan ... too much work. trust me , 21 years working for IBM .. i'm used to see stuff like this.
2020-10-27
Superfly-
Malaysia
TruGreen Posted at 2019-11-26 08:32
this is wrong as well. in post #5 you have a totally different part circled... in this picture in Post #6 the little black square is covering what you have circled in post #5
That's the same pcb board with different version.. Big chunk of components are missing..
2020-10-30
djiuser_z34Z5TKVJ9LB
Bangladesh
what is the name of this??? and its  function??
2021-1-11
m80116
Flight distance : 3264131 ft
So 2021 has come... anybody offering a scan of a DJI Mini 2 board ?  ;)
2021-1-11
djiuser_BtZAS9MBNExU
Flight distance : 1278294 ft
Does anyone know if there is any other way that we can identify which board is installed in the mini, other than to. disassemble and inspect? ( serial number, etc..)  , Here is what happened to me a few months back:  I had a Mavic mini, that I received as a gift. The mini had just come out and I was already a M1P owner, so It was really fun to fly a small, somewhat as capable drone as the M1P and at such remarkable range that I was pretty blown away by how inexpensive it was for such a great product! I was flying everywhere, and the Range of the flights were amazing! I ended up cashing in on one of my Care Refresh Replacements, It is a great deal. However, the replacement that I received was nowhere near as thrilling to fly as the original one, and the range it was getting along with the steadiness and longevity of the video transmission were much diminished. Ultimately, during an at home, close range flight, the bird takes off over the trees completely unable to be controlled by me whatsoever! There are several warnings that were showing on the App, and RTH was unresponsive. I was immediately in fear that something terrible could happen to someone, or secondly someones property could be damaged and I could be held liable and Thirdly, not to mention, .. my $400 drone is gone!  Could this be a result of receiving a Replacement Mini with a CE board, and perhaps the original Mini that I had was built with the FCC version?
2021-1-21
Billy Thomson
Here's my main board now dead an burnt after being in the canal for a few days
2021-3-22
Anurudda Abeykoon
Sri Lanka
Dear sir madam my drone is dji mini drone is no power sumtime on off i want buy in main pcb board what the resan to buy or repair
My email anuinnovationsl@gmail.com
0094 0703000935 wattapp
Pls saport me
2023-9-20
Anurudda Abeykoon
Sri Lanka
Pls saport me
2023-9-20
Sean-bumble-bee
Flight distance : 15997 ft
Anurudda Abeykoon Posted at 9-20 06:02
Buying a working second hand drone it probably going to be a cheaper option.
2023-9-20
12
