SOLVED: ICE don't wanna stitch a sunset side of a sphere!
12Next >
1275 41 2019-11-28
S-e-ven
Flight distance : 5922034 ft
Thailand
I opened a topic under works, but I am not sure that works. ;-)
Anyway, there are pictures to this problem with ICE
thanks
https://forum.dji.com/thread-203129-1-1.html
2019-11-28
Montfrooij
Flight distance : 2560453 ft
It is a hard one with little detail in many parts of the sphere.
At least, Autopano giga is usually fooled by this and I have to change the stitching by hand.
2019-11-28
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for reaching you to DJI Forum. I am sorry for the trouble that you are experiencing. With regards to the third party software ICE. I would highly recommend to contact ICE support to isolate the issue. Thank you for your valued support.
2019-11-28
S-e-ven
Thailand
Montfrooij Posted at 11-28 07:10
Autopano giga, discontinued?
2019-11-28
Montfrooij
S-e-ven Posted at 11-28 20:28
Yup it is.
You can find 'trial' versions online and it will still work.
2019-11-28
S-e-ven
Thailand
Montfrooij Posted at 11-28 23:32
Yup it is.
With or without watermark?
I'll test it in the next days!
2019-11-29
Montfrooij
S-e-ven Posted at 11-29 01:31
It is 'trial'
(you know a 'trial' that never ends)
2019-11-29
S-e-ven
Thailand
Montfrooij Posted at 11-29 01:33
It is 'trial'
I'll try(al), will see
2019-11-29
Montfrooij
S-e-ven Posted at 11-29 02:04
I think I got it here if you can't find it.
2019-11-29
S-e-ven
Thailand
Montfrooij Posted at 11-29 02:10
Oh, if they work, I got them ;-)Will try, later
2019-11-29
S-e-ven
Thailand
but:
Can you tell me, WHICH version is your "forever trial" one?
Just in case ...
2019-11-29
Montfrooij
S-e-ven Posted at 11-29 02:28
[view_image]
Those should be it.
2019-11-29
Montfrooij
S-e-ven Posted at 11-29 02:29
but:
I use the giga version.
2019-11-29
S-e-ven
Thailand
Montfrooij Posted at 11-29 03:05
Short test:
Progress in sight.
Thanks for the tip!
2019-11-29
dji_MODDER
Flight distance : 73209 ft
@ s-e-ven did you check my Pm
2019-11-30
dji_MODDER
Also check group settings like this
2019-11-30
dji_MODDER
then the color correction
2019-11-30
dji_MODDER
and render setting
2019-11-30
dji_MODDER
Try to shoot in dlog and import raw(DNG) photo's to stich due to the most detail and information on the photo, and you are good to go
note, use spherical, or little planet(for a 360), because I see in your example cylindrical
2019-11-30
S-e-ven
Thailand
dji_MODDER Posted at 11-30 00:56
I just did, thank you, that worked well!
2019-11-30
S-e-ven
Thailand
dji_MODDER Posted at 11-30 01:28
I will try your settings, for sure.
Autopano is totally new to me, so I just checked it out, if it can "see" something else/more, compared to ICE .
It could, which's promising!
To "dlog/raw" : not before another drone, methinks. Unless DJI gives that to the Spark, I do stuck with mp4/jpg
I think I know now, why ICE isn't getting over this, why autopano also has trouble.
I usually set the AE lock manual in the sunny part, but with just the ocean under it, I "normally" start the capturing somewhere on the structured land part.
(I have lots of these sunsets, over ocean, and got them stitched with just the usual water "blacked" parts)
Looks like that the scenery and colors kept me to excited, to think on this.
2019-11-30
S-e-ven
Thailand
It's getting better, but I am on the last (stable?) version.
Perhaps I have to get to an older one, to have the same info shown, like in the guides I can google.
Right now, I can not make the 15 missing pictures show up.
46 uploaded, 31 in use, there should be the "guess position" function available, but ....!
I think, I need more time with this!
2019-11-30
Montfrooij
S-e-ven Posted at 11-29 17:18
Short test:
Progress in sight.
Thanks for the tip!
Nice!
You can align images later on.
It is a bit tricky, but I can help if you need.
2019-11-30
S-e-ven
Thailand
Montfrooij Posted at 11-30 11:36
Nice!
Wanna help? Needed! THANK YOU!
I am stepping slowly forward, now I am alining and turning pictures, but:
What is the secret of this circle ones?
How to "make 'em normal squared pictures", again?
Or would it be better, to start aligning them all manual, starting at 1 and going to 46?
2019-11-30
dji_MODDER
in settings try, force every photo in one panorama
2019-12-1
S-e-ven
Thailand
dji_MODDER Posted at 12-1 00:39
I did force all in one pano.
Thats why all 46 are in, this time.
46 still is, even with a horizon line in the middle, under pic 45!
Normally it would fit between 44/45 to the left and 1/2 to the right
1-7 I found more on the left, under other pictures.
I may start over, with just the horizon pictures.
Will see, it is a bit challenging, this picture
2019-12-1
dji_MODDER
Yes I think also, normally it should work.
2019-12-1
Montfrooij
S-e-ven Posted at 11-30 20:59
No, you have to do it like so.
They won't get square. They are made into perspective.
I have to look it up for you.
Where is your menu?
2019-12-1
S-e-ven
Thailand
Montfrooij Posted at 12-1 07:32
I am starting to understand autopano, methinks.
Still a lot to learn, but it shows a (learning;-)curve:
2019-12-1
Montfrooij
S-e-ven Posted at 12-1 09:57
Nice.
There is one setting I turn OFF most of the time.
That is the auto correction (it is a rainbow colored button in the menu)
You can set it off default too.
2019-12-1
S-e-ven
Thailand
Montfrooij Posted at 12-1 23:23
Nice.
Will think/check about that, eh, later ;-)
I am still trying to get all 46 images in one picture
2019-12-1
Montfrooij
S-e-ven Posted at 12-1 23:27
If you keep having troubles, send the batch over.
I can try and document the process
2019-12-1
S-e-ven
Thailand
Montfrooij Posted at 12-1 23:33
Generous!
But right now I have a reason to figure that out myself.
In case I can't make it work, I will consider and get back to your  offer.
Thank you
2019-12-1
Montfrooij
S-e-ven Posted at 12-1 23:44
Generous!
My pleasure!
2019-12-2
dji_MODDER
here one with a little planet
2019-12-2
S-e-ven
Thailand
dji_MODDER Posted at 12-2 05:12
[view_image]
Nice on!
I still fighting with mine! ;-(
2019-12-2
S-e-ven
Thailand
[view_image]
Did it!
Autopano is a great editor:
(still not perfect, but ... ;-)
2019-12-2
S-e-ven
Thailand
No need, I think!
Thanks for the help!
2019-12-2
Montfrooij
S-e-ven Posted at 12-2 08:14
No need, I think!
Great!
Nice nice job!
2019-12-2
Montfrooij
S-e-ven Posted at 12-2 08:13
Did it!
And indeed. Far from perfect.
That is probably why they ditched it after all.
2019-12-2
12Next >
