slup
Flight distance : 1607103 ft
Sweden
Lucouto Posted at 3-24 13:41
I’ve just crashed! I can’t see a reasonable cause for the crash... Mavic Mini took off and I didn’t noticed the warning right away at started the flight. And then, crash!
I’d love to post the link to the logs here, but it seems I can’t (don’t know why). Try here: app.airdata.com/share/lmLlyf
This isn't anything else then the famous "uncommanded descent" phenomenon so typical for the Mini ... In the end just after you had released the throttle (Yellow) for the last ascent up to 15,7m (Red) you go full elevator (Purple) during 3sec, the heading speed (Green) goes up to only 2,5m/s. Just before reaching that top speed forward at 26,5sec into the log the Mini decreases the pitch angle (Magenta) & the descent speed (Blue) picks up & reaches 5,7m/s down at 30,7sec into the flight ... totally uncommanded.
To diagnose this event beyond doubt the mobile device DAT log is needed so we can access the motor data ... The correct DAT log have FLY030.DAT in the end ... check here how to retrieve it from the device you flew with --> Flight log retrieval and analysis guide Read under point 3.
This isn't your fault ... open a case with DJI & point them to the logs ... & this post if needed.
(Click on the graph to make it larger)
