JJB*
Flight distance : 12132231 ft
Hi XBower,
Happy that you like FRAP, already add a DAT file into FRAP? (great to see wind data...and more DAT events)
Your question: FRAP software does a check on each record on uncontrolled Up and Down movements ; it will check current baro height and with no up/down RC stick command height should not change the next few records. (some delay after input to zero stick is taken into account)
Ofcourse it will go up/down a little, normal behaviour.
So if you check this option and the NoControlUp/Down is only momentarily; no problem. If this message is there for many records in sequence ; than check this and find out by checking other values ect if it is an 'error' or not.
For a MM and MA2 in the messages menu you will see all kind of FRAP logic check values, in the Option menu checked that option and the values are seen on the main screen and in the Flight Summary.
If you doubt your log, just sent it to me. (how to contact me : in FRAP)
cheers
JJB
