Mini not stable when hovering
8101 12 2019-12-17
djiuser_1ZCi2A1yLb9S
Romania
After 8 flights my Mini is not stable anymore when hovering. I was flying it in a big interference zone and i noticed that is not stable in hover, it have a little side to side balance so i land it. Then i take off again and i keep it in front of me at 2m high to observe it. And it went slowly up and down and on sides, not much, some centimeters. The outside temperature was more than 10C. I did the IMU and compass calibrations, i tried after, the same. I changed the place, i have recalibrate, nothing, i went indoor, recalibrate, nothing. It records the home point and the firmware is updated. Until now it was staying perfectly still, outside or inside. Can you please help me?
2019-12-17
DJI Stephen
Hello and good day. I am sorry to read and to know what is happening on your DJI Mavic Mini. May I know if the said drone had a hard landing or a crash before this issue happened. May we also know if you have check the propellers of the said drone if there are damages that might cause this issue. Please keep us posted on the said issue for us to be able to assist you further. Thank you.
2019-12-17
Romania
DJI Stephen Posted at 12-17 11:25
Hello, thank you for your answer. No crash or hard landing. The propellers are fine from what i see. When it hover i can hear some motor(s) going faster, louder, like working harder to keep the Mini in the air.
2019-12-17
Bright Spark
Flight distance : 22129 ft
If it's accurate to few centimetres, I would say it's ......perfect plus.
It requires some moments to register movement and correct , on gps and barometer readings.
You would have to nail it to the floor to do better.
2019-12-17
Romania
Bright Spark Posted at 12-17 11:40
If you let it in the air in hovering more than 10-20 sec it will go up and down for more than 10cm
Until now it reallly stayed in the air like it was on the floor
2019-12-17
DAFlys
Make sure you have at least 11 sattelites and then you could post a flight log here which might show some errors - https://www.phantomhelp.com/LogViewer/upload/
2019-12-18
djiuser_FM1kbXvtWtfw
HI everybody , i have the exact ptoblem with my DJI MINI 1. I dont know how to fix it. i have recalibrate , the dompass, IMU the Controller. and update the firmware via Dji assustant 2. And the issue seem not to be fixed. I would need the connunauty help. Thank you all.
2023-8-28
Sean-bumble-bee
Flight distance : 15997 ft
Is this indoors or outdoors and if outdoors what time of day and when is your sunset/sunrise, i.e. how well is the ground illuminated?
2023-8-28
DJI Tony
djiuser_FM1kbXvtWtfw Posted at 8-28 06:21
Hello there. Thank you for reaching out. Can you please try the notes below?
1. Ensure that the aircraft mode is normal, i.e., the GPS signal is strong and the aircraft is in non-ATTI mode.
2. It will be better to provide us with a video for us to determine.
3. Try flying to a different location.
4. Check the propellers and the state of the motors. Check whether any motor rotates abnormally when the propellers are not mounted.
5. Confirm that there is no magnetic interference. It is recommended to place the aircraft on level ground for IMU calibration and compass calibration.
6. Check whether the control stick is being pushed. If the stick movement is offset, the remote controller should be calibrated.
Please keep us posted. Have a great day ahead.
2023-8-29
djiuser_Z9FtyKFfHfOT
Indonesia
Hi , I had a small crash with my dji mini 2 and a propeller broke.. I've swapped it correctly but not the drone is not stable at all while hovering and it hovers at a slight angle , it's not kevel, any idea what is wrong? Everything else seems to be fine.
Thanks
2023-11-9
Labroides
Flight distance : 9991457 ft
djiuser_Z9FtyKFfHfOT Posted at 11-9 21:03
Thanks
The first thing to do would be to recalibrate the IMU.
2023-11-9
Sean-bumble-bee
Thanks
Did you replace BOTH blades on the affected motor?
Perhaps you could post a photo of both blades that are currently on that motor and a photo of the drone in flight that shows the "slight angle".
2023-11-10
DJI Tony
Thanks
Hi there. Sorry about the inconvenience. Please try the notes below:
2. Check whether the device drift or unsteady hovering is within the hovering accuracy range, which is shown in the Specifications of the corresponding product on the DJI official website.
3. Try moving to another flight environment to test.
5. Make sure that there is no magnetic interference. It is recommended to place the aircraft on level ground for IMU calibration and compass calibration.
6. Check the control stick. If the stick movement is offset, the remote controller should be calibrated.
Have a nice day.
2023-11-11
