Sigmo
I will try this "fix" when I have a chance.
I'm sure some of you must have seen the two videos on YouTube where the reviewer had problems with his Mini dipping down while he was flying at an elevation slightly over 5000 feet. He noted this in his review.
Soon enough, DJI contacted him and gave him new propeller blades and new firmware. This corrected the problem, and in his follow up review video, he flew at an elevation above 10,000 feet with no problems and with good battery life.
Clearly, that means that the prop blades were redesigned to give more lift at higher elevations.
I live at about 5200 feet. I get short battery life here, and the insufficient power problems when flying with the prop guards mounted, even at a hover.
I have wondered from the get-go if my Mini came with the new or the old style prop blades.
If someone gets a Mini that has the old style blades installed, and has problems, swapping for new style blades could give a cure. |
