Bright Spark
Flight distance : 22129 ft
True. The constant voltage however takes over from (ideally) constant current which dominates until max voltage is reached, but more charge at a dimishing rate is still possible.
Yes obviously the power supply has no intrinsic charge control circuitry, but it's behaviour causes it to vary its supplied current, because of the load's varying requirements.
I gather mini's batts are lion, and they appear light on internal charging regulation and cells may not be balanced at all, looking at some tear down videos where people are already fitting larger capacity batts.
In case I'm rightly called out again, I feel I must add that we have looked only here at the controller batt. If this were a 1 amp/hr batt, it would take 1 amp for 1 hr to charge from flat.
The mini's batts are I think 2.7 a/hr capacity, and therefore require 2.7 amps to charge in an hour.
At the currents shown that would be over 5 hrs to charge. 18 watts from usb charger is c 2.5 amp at 7 volt and barely do 1 in 1 hr. |
