Minnesota
Ice_2k Posted at 12-24 00:21
maybe. Or maybe it's just about the positioning of the sensor. Although I tried it in all possible positions and there was no effect on the compass reading, no matter how it was positioned compared to the RC. So thinking about it, yeah, I think Apple just did a better job of shielding the compass from outside interference than Samsung did.
Not all phone compasses are magnetometer based. The electronic ones combine your movement using GPS and your recent "rotation" using the 3-axis accelerometer data to determine where you are, what direction the phone is pointing, and then calculates from this where magnetic North is. These are not as accurate, and if you are just standing there flying a drone and not moving much, it could be pretty far off.
To make matters worse, the Compass function really isn't activated in the phone until you start the App (DJI Fly). If you do that when you are just about to take-off, the electronic based compasses don't have much information on which direction the phone is pointing, so it could be seriously off. Perhaps this is the reason the Aircraft Orientation function with some phones seems to initially not work but then appears to work; the pilot moved around long enough for the algorithm to work. The opposite could also be true, that if the pilot does not move around much while flying, the electronic compass drifts and therefore the Aircraft Orientation function drifts. Either way, I'm right. |
