Phantom 4 pro plus v phantom 4 pro v2
889 2 2019-12-29
mattjuk47
Flight distance : 38399 ft
Hi,
I have just bought the phantom 4 pro plus, I noticed the video software is  Lightbridge, should it be Occusync ?
what is the difference between the PRO + and V2 ?
Thanks as always for the help
Matt
2019-12-29
DJI Stephen
Hello and good day Matt. Thank you for reaching out and for the inquiry. The DJI Phantom 4 Pro V2.0 uses the same camera as the DJI Phantom 4 Pro and is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video at 100Mbps. Also, like the DJI Phantom 4 Pro, V2.0 features a 30-minute maximum flight time and 7-kilometer long-range control. The remote controller of the DJI Phantom 4 Pro V2.0 also supports 2.4 and 5.8GHz frequency switching, and a remote controller a with built-in screen is also available. Different from the DJI Phantom 4 Pro, the DJI Phantom 4 Pro V2.0 is equipped with an OcuSync transmission system, which allows the drone to connect to DJI Goggles wirelessly. The DJI Phantom 4 Pro V2.0 also features an upgraded propulsion system with FOC sinusoidal driver ESCs and 9455S quick-release propellers that reduce noise and make the drone more aerodynamic. ( The remote controller of Phantom 4 Pro V2.0 is not compatible with the Phantom 4 Pro, which uses Lightbridge transmission. Other accessories such as batteries, chargers, and ND filters are compatible with both the Phantom 4 Pro and Phantom 4 Pro V2.0 ). Thank you.
2019-12-30
mattjuk47
DJI Stephen Posted at 12-30 12:11
thanks for post and reply,
I know the differences between 4 pro,
What I wanted to know is the difference between 4 pro plus and the 4 Pro V2, are they same machine but for different markets - Europe  v USA ?
Many thanks again
Matt
2019-12-30
