JJB*
Flight distance : 12225059 ft
Hi,
You started your flight with not so many satellies and bad reception.
During flight in and out OPTI mode, so my guess is that the GPS error is beacuse of this.
My advice is to start flying with a higher number of satellites and with a good reception as wel.
Mayby the high buildings around you blocked the GPS signals.Number of sats is important but also how widely they are spread-out in the sky.
8 receiving sats close to each other are not that good for positioning, plus you do not loose 1 but more at the same time as the signal is blocked.
Many happy landings,
Cheers
JJB
