grahamjohnson10
Flight distance : 2817172 ft
StubbornSwiss Posted at 12-31 06:48
OK....... so using DJI Assistant 2 For Mavic, I updated the MM and each of the 3 batteries, as well as the RC.
I powered up the MM in the basement, and got a lock out, which I was easily able to override. I will attach screenshots of the sequence (in order) which should be pretty self explanatory - picture 2, you tap on the "Unable to take off" warning to get to the next screen, and of course you then tap on "Unlock". After this, I hovered as usual, still as stable, with no issues what so ever, other than a couple of low light warnings which I had never seen before when hovering in this same location. (I probably should set up a screen recorder to capture those).
Thanks, that's great. |
