Giuseppe ITA
thE29 Posted at 5-18 02:09
The non-us version even lacks a hardware-modul. So, when the EU regulations are finished, DJI will probably make the Air2 fit to match it.
But the old ones, dont get magically a hardware module and therefore I doubt they will automatically fit in the same category.
Those UAS that will not comply EASA Regulation (as the Mavic air2 before EASA rules apply) will be forced in A3 category, UAS below 500 gr will fly in A1 untill 2022
Article 22 - Transitional provisions Regulation (EU) 2019/947 Without prejudice to Article 20, the use of UAS in the ‘open’ category which do not comply with the requirements of Parts 1 to 5 of the Annex to Delegated Regulation (EU) 2019/945 shall be allowed for a transitional period of two years starting one year after the date of entry into force of this Regulation, subject to the following conditions: (a) unmanned aircraft with a maximum take-off mass of less than 500 g are operated within the operational requirements set out in points UAS.OPEN.020(1) of Part A of the Annex by a remote pilot having competency level defined by the Member State concerned;
UAS.OPEN.020
UAS operations in subcategory A1 shall comply with all of the following conditions:
(5) be performed with an unmanned aircraft that:
(d) is marked as class C1 and complies with the requirements of that class, as defined in Part 2 of the Annex to Delegated Regulation (EU) 2019/945 and is operated with active and updated direct remote identification and geo-awareness systems.
