Mark The Droner
Flight distance : 2917 ft
Sorry for your loss.
Here is a better site for looking at your data: https://www.phantomhelp.com/LogViewer/TNYXPG6IOYSMO6R99VF1/#
The beginning of the log is odd. It shows a time of 7m 42 secs before you launched. A normal log would show 0m 1 sec before launch. It appears you flew a flight for around 7 mins, landed, turned motors off, and then started motors for a second time and took off again without turning off the AC/battery. Hence, the old log closed and a new log opened.
You launched with only 58% battery which is normally a pilot error. One must always launch with a fully charged battery because history has shown a great risk of sudden drop in the sky otherwise. But if you had been on a previous flight and never turned off the battery, that risk is removed, from what I've read from many posts.
Two mins into the flight, the smart battery requested to Go Home. You took your hands off the sticks at that point, apparently to cancel the Go Home request via the app screen. You then put your hands back on the sticks, made an adjustment in yaw to aim east, and the pushed both sticks extreme full forward as you continued to fly further away at top speed while gaining altitude at top speed..
I don't see an explanation for your losing signal at the end of the log.
The puzzling thing is, the log shows you racing home in RTH with the right stick full forward, but then returning the stick to mid point only a few seconds before the end of the log. Apparently your FPV locked up and so you instinctively let go of the right stick. Then you lost the downlink completely with 27% battery and almost a mile and a half away.
So in theory, if all was well with the AC, it would then putter home at about 21 mph, but it will start auto land at 10% battery. You seem to have a nice balanced battery.
It would take you about 4.5 mins to reach home point, but then it would have to descend too. You were 1100 feet up, so it would be a long time-consuming descent. The smart battery may have forced the AC to land sooner (further away). It may have calculated you didn't have enough battery to land, even if you had enough to make it overhead.
But none of this explains the disconnect.
It may have landed safely somewhere in those fields, or it may be in pieces somewhere in those fields or even the woods. MHO
Good luck
