I intend to send the questions outlined below to the FAA. As I don’t believe the website that was setup to receive Proposal specific feedback is also a place to ask questions, I will be sending this to - UAShelp@faa.gov
I am hoping to receive answers of “True” to all three questions in which case the widespread concern regarding not being able to fly outside of a 400-foot bubble, in remote areas where there is no internet service, will hopefully be assuaged.
RE: [Docket No.: FAA–2019–1100; Notice No. 20–01]
RIN 2120–AL31
Remote Identification of Unmanned Aircraft Systems
AGENCY: Federal Aviation Administration (FAA), Department of Transportation (DOT).
ACTION: Notice of proposed rulemaking.
In regard to the above proposal could you please provide True/False answers to the following:-
In the scenario described below It is assumed that both the UAS and associated remote control device (e.g. iPhone) are fully compliant in terms of their abilities to connect to an internet-based USS and to be able to also perform Direct ID (message elements) broadcast via radio frequency spectrum.
Question 1: In a remote area where there is no wi-fi or cellular-based internet service available the fully compliant UAS will be allowed to take-off and fly beyond 400 feet horizontally (as per Limited remote identification UAS) provided that it is directly broadcasting the required message elements via radio frequency spectrum and that VLOS is maintained for the duration of the flight? True or False?
Question 2: In the above scenario the intention is for low flying aircraft and law enforcement personnel operating in the vicinity to be able to receive the ID message elements being broadcast by the UAS and thus determine its location (such as GPS coordinates and height AGL). True or False?
Question 3: There is no requirement for the ID message elements to actually be received by any aircraft or personnel which would obviously be the case should none be within the range of the broadcast for the duration of the flight. True or False?
