Controller charging phone/tablet
12Next >
12556 44 2020-1-6
fans461cbed1
Flight distance : 8117 ft
Belgium
Hi all,
you might have noticed your controller is charging your mobile phone (or tablet) when connected with the OTG cable...
What's the point of that small 2600mAh controller battery charging a much larger 3000-5000mAh battery on your phone or tablet?
If my phone or tablet is only 50% charged, it will still work for several hours.
This is a pure hardware configuration and the charging function can not be disabled with a simple firmware update...
So I wonder if there are OTG cables (or adapter) on the market that only transfer data and not the power.
I know there are certain usb cables that only transfer power and can't be used for data transfer. (Like cheap charging usb cables)
Does anybody know about the opposite?
So cables that only transfer data and not the power?
2020-1-6
Ice_2k
Flight distance : 1132575 ft
Romania
I suppose you're using Android, as this is not happening for iPhones. I remember seeing a tutorial, there is a pin on the cable responsible for the +5V, you can scratch that pin off and prevent it from transferring power. I don't know if you can find something like this ready to buy.
2020-1-6
spanzetta
Flight distance : 1124738 ft
AFAIK the OTG power management configuration (Host/OTG-A/OTG-B device) can be controlled by SW.. if DJI want they can solve it.. I assume they are simply not taking care about that...
iPhone/iOS is not affected because has a different support (more limited) for OTG
2020-1-6
DJI Stephen
Hello and good day. Thank you for reaching out and for sharing this information with us. Regarding the DJI Mavic Mini's remote controller charging the Android devices. In relation to this matter the Android mobile device needs on-going 500ma to maintain the USB connection, so there is no option for the Android device to disable the charging mode, it is related to the android system and the communication protocol. This is regulated by the Android Open Accessory ( AOA ). Thank you for understanding and support.
2020-1-6
fans461cbed1
Belgium
Ice_2k Posted at 1-6 07:58
Yes, I also thought about disconnecting the +5V wire. But those cables are so small and thin... it will be a difficult job to get a clean result...
So the Apple devices are not charging???
2020-1-6
fans461cbed1
Belgium
DJI Stephen Posted at 1-6 08:01
Ok thanks Steven for fast reply!
I now understand why the power is needed.
Does this mean the max. charging current from the controller to the android device is only 0,5A?
If that's the case it is not that big of a deal.
I assumed the charging current would be higher.
2020-1-6
Akirasho
Flight distance : 1644009 ft
Agh!   yet a other fact it would be nice to know in advance of buying.  I guess I can fight back my keeping the Samsung topped off! before a flight session!
2020-1-6
fans461cbed1
Belgium
Akirasho Posted at 1-6 08:16
So many things to know before we buy...
I purchased a Samsung Galaxy S9 because my older Samsung phone could not run the Fly App.
Should have purchased the Iphone... Grrr!
2020-1-6
Minnesota
My bench test shows this issue.   The times I got were better than DJI specifies.  What I'd like to know is "Does the RC transmit when there is no drone connected?"  This could account for the longer times (uses less battery).  Perhaps someone here knows.
2020-1-6
spanzetta
Sorry but reading at Wikipedia it appears that the power configuration can be controlled by SW..
https://en.wikipedia.org/wiki/USB_On-The-Go
USB OTG defines two roles for devices: OTG A-device and OTG B-device, specifying which side supplies power to the link, and which initially is the host. The OTG A-device is a power supplier, and an OTG B-device is a power consumer. In the default link configuration, the A-device acts as a USB host with the B-device acting as a USB peripheral. The host and peripheral modes may be exchanged later by using Host Negotiation Protocol (HNP).
2020-1-6
fans461cbed1
Belgium
Minnesota Posted at 1-6 08:21
https://www.youtube.com/watch?v=cQl2G3BmBvQ
Interesting video!
I suppose we don't have to worry about the current used for the androids.
It's clear that the draining current is low.
The current used (0,5A?), is lower than the discharge current on the phone.
Even with the charging function, the phone was showing lower voltage % after the test.
2020-1-6
fans461cbed1
Belgium
Specs say draining current 1200mA for Android and 700mA for IOS.
So there is the 0,5A in difference!
Battery is 2600mAh.
On Android that gives little more than 2 hours till fully discharged.
Your video test is correct I guess.
However, I would never go that far during flight
2020-1-6
JodyB
Flight distance : 302536 ft
I think what DJI Stephen is trying to explain is that it is required to maintain USB connection. Now, that being said, I just about say there are folks out there that has that +5v pin disconnected and maybe working just fine. To be upfront, I can't say one way or the other if it would work properly. We need some input from folks that have actually done this to confirm or deny if it truly needs the power to maintain a working USB connection. If it doesn't, then DJI needs to do some testing in that area. But they maybe going by the protocols they mentioned and are required by those protocols to do it in the way they are. Needs quantitative input to know for sure though.
2020-1-6
Francoisd
Flight distance : 66352 ft
Hi,
In my case, I have an Iphone 8 and it is charged by the radio through the genuine cable .
2020-1-6
ChrisM101
Flight distance : 4072 ft
Francoisd Posted at 1-6 09:09
Hi,
It doesn't even have to be deleted just offer a soft switch. Like maybe if the phone goes to low power but its annoying.
My phone at 50% would last all day including flying. Stop trying to charge it.
2020-1-6
Akirasho
Chicks love red sticks (runs and hides before being called a male pig)
2020-1-6
fans461cbed1
Belgium
Hi,
What?!?!?!?
2020-1-6
JodyB
Hi,
iPhone XR and iPad air 2 does not charge when connected to the RC for me.
2020-1-6
fans461cbed1
Belgium
JodyB Posted at 1-6 09:05
Stephen explained me perfectly what's the reason for the Android charge.
After reading all posts I'm sure the current is low and will not affect the working of the controller to much.
So I'm gonna leave things the way they are and not mess cutting the +5v wire.
100 minutes of operating time is more than enough to fly and discharge 3 main battery packs.
2020-1-6
Minnesota
I think the RC was designed to provide up to 500 ma of current per the AOA standard requirement, but that doesn't mean the connected device would draw 500 ma.
2020-1-6
Francoisd
JodyB Posted at 1-6 09:20
Perhaps due to too low current provided by the remote bu which is sufficient for charging an Iphone 8. Il will try mith my wife's iphone 8+ to see.
2020-1-6
fans461cbed1
Belgium
Just me brainstorming:
How about installing a splitted OTG cable (Y-cable)?
Connect to transmitter, connect to phone and connect to small external powerbank.
That would charge all, even during flight...
Any testpilots out there willing to try this?
Before I blow up my own transmitter ;-)
2020-1-6
LRaven
Ukraine
https://forum.dji.com/forum.php?mod=viewthread&tid=82832&extra=page%3D1%26filter%3Dtypeid%26typeid%3D556%26typeid%3D556
2020-1-6
fans461cbed1
Belgium
LRaven Posted at 1-6 11:50
Nice!
On the MM we'll need only 2 wires.
To keep it portable, a small powerbank (with internal data transfer) would be the way to go.
Will start looking for that asap!
2020-1-6
DJI Stephen
fans461cbed1 Posted at 1-6 08:11
You are very much welcome. If you have any other inquiries or concerns with DJI. Please feel free to post it here at DJI Forum. We are all here to help and support you. Thank you and fly safe always.
2020-1-6
djiuser_ft3PdO5SU9R7
Flight distance : 993100 ft
Yea, it's the same sh*t with the osmo pocket, well that's even worse with it's smaller battery
2020-1-6
spanzetta
Dirty Bird Posted at 1-6 19:40
It is a limitation of Android unless you root your device.  Not sure why stock Android doesn't allow users to disable charging?
apparently it's not so generic (all Android)..  and anyway it also depends on how DJI implemented the USB on RC.. I am almost sure that if they want they can manage this at sw level..
nice discussion here..
https://mavicpilots.com/threads/android-usb-charging-disable.53493/
2020-1-9
DowntownRDB
Flight distance : 1722 ft
This individual came up with a nice workable solution.  Appears he is trying to grow interest and then commence making the product.
As I use two non-rooted Android phones to fly my MM I'm going to go ahead and sign-up for one of these Charge Blockers.
2020-1-16
Minnesota
DowntownRDB Posted at 1-16 05:23
https://www.youtube.com/watch?v=iNP_e3bY1NM&feature=emb_logo
Thanks.  I pre-ordered too.
2020-1-16
virtual
Flight distance : 4897142 ft
Czechia
spanzetta Posted at 1-9 12:03
You're right, it looks like my Xperia Android phone is not charged from DJI controller...
2020-1-16
Miixxa
Flight distance : 280682 ft
Finland
fans461cbed1 Posted at 1-6 09:27
Did you PM with Stephen or what?
I'm not buying the 0,5mA discharge thingy since my Huawei Mate will always start to quick charge (according to the phone) from the Mini RC if I allow it. QC needs a whole lot more amps than point five...
Luckily Huawei prompts me everytime I connect the USB to choose if I want to charge or transfer files (yeah huawei thinks the RC is a PC), and if I just cancel the action it won't do any of those things.
Can also see it while flying, if I've enabled phone charging the RC is pretty much completely dead after 3 batteries. If not enabled there's still like ~30-40% charge in the RC after 3 AC batteries.
2020-1-16
spanzetta
virtual Posted at 1-16 10:18
that confirm that it's not true (as DJI said) that in order to work on Android the Recharge cannot be avoided..
We should insist asking DJI to solve this at their SW/FW level.. I am sure they can do!!!
2020-1-19
lifeisfun
If you use rooted device just install Battery charge limit from the playstore. You can set limit when the device wil start charging and also level of maximum charge allowed.
Sadly my favorite device to fly ( Note8 Snapdragon ver 1200nits ) can not be rooted
2020-1-19
lifeisfun
Minnesota Posted at 1-16 07:07
If you are handy you can patch the cable your self using resistor and avoid the bulky adapter.
2020-1-19
djiuser_oojJpiOHuyk0
Your cable needs to have USB Micro-A connector.
When I use USB Micro-B connector it charges.
The controller will accept both types
2020-3-7
Pashi
Flight distance : 4862598 ft
Russia
When using OTG cable with my Xiaomi MI6 & DJI Spark and battery indicator of the phone shows about 50% the connection is starts breaking and connecting every second, and I can't fly with OTG, only with Wi-Fi. Hope this will not happen with Mavic Mini otherwise I cannot fly with my device. Does anyone have experience with Minic & Xiaomi Mi6?
2020-3-8
Axotopia
Flight distance : 37536 ft
Miixxa Posted at 1-16 10:37
Think the Huawei EMUI Android implementation always asks what the USB cable connection should do ....  Charge from device, transfer file etc.
My Huawei P30 Pro and MatePad Pro tablet always ask whenever I plug the RC to the phone or tablet, so never had any issues of draining the RC battery.
2020-3-12
Ralle
Flight distance : 11289 ft
Finland
Axotopia Posted at 3-12 23:00
I have a Honor 8 x when connecting the computer to the usb port so it asks for, downloading, data transfer, photos.I haven't tried with the controller yet.Is it then possible to use only data transfer?
2020-3-12
Axotopia
Ralle Posted at 3-12 23:22
Should be able to select Data Transfer Only; that is what I select on both the P30 pro and MatePad Pro.
2020-3-26
Ralle
Finland
Axotopia Posted at 3-26 10:37
Thanks a lot
2020-3-27
12Next >
