Geebax
I have been saying for some time that the problem is caused by the movement of the mini causing pressure changes within the body of the aircraft. I do not believe that the barometer is misbehaving at all. The slightest pressure change translates to tens of feet of altitude, so the aircraft is very sensitive to the most minute pressure difference. And, although I do not own a mini, I tend to think that the vents designed into the body are what is causing the pressure changes.
I suspect that as the aircraft flies along at speed, the air moving through the vents causes a fall in pressure, translated to the aircraft ascending, but it maintains its current altitude because the pilot is controlling the aircraft. As soon as you stop, the flight controller is responsible for maintaining altitude, it then thinks the aircraft is too high, so it begins a descent to regain position. Then the pressure returns to normal because there is no forward movement, and the aircraft again rises back to where it should be.
DJI, in offering to replace the barometer in Guorium's aircraft, really don't have a clue as to the problem, these are simple component jockeys. I believe the problem is the body design with the vents having an unwanted effect on the performance of the aircraft. If I am correct, then no firmware/software change is going to cure the problem, it is a design fault in the body of the aircraft.
PS. I do not believe it has anything to do with temperature either, it is just an air pressure thing. And because it is all taking place inside the automated routines of the flight control system, I do not expect you will see anyting in the flight logs showing it occurring.
