Daninho
Flight distance : 70203 ft
OK, you have the Phantom 2, not Vision and you want a FPV System. To use your Surface tablet as an FPV monitor will be a problem because FPV is anolog technic with low resolution, you need a special FPV monitor and a FPV transmitter. The only way to use your tablet as an FPV monitor would be when you buy a digital FPV system like the DJI Lightbridge but this is a 1500 dollar system. Analog FPV screens are cheap, like 80 dollar, even if you could use your tablet it would make no sense because the FPV resolution is so low, you dont need a Full HD tablet to show 640x480 |
