BlackboxTMLPS
I have two Osmo Actions that I use at the same time. Both appear on the DJI Mimo app (on iPhone Xr, Mimo V1.2.13(54841)) in the Device Connection section but when I connect to 1 of them, it remembers that one and wont let me connect to anything else. The camera button in the top left corner on the home page becomes dedicated to that camera I just connected to and won't 'let go' of it until I switch that osmo action cam off, then I can get back to the Device Connection menu to choose that other camera. Even if I exit and re-open the app, it is still stuck on the first camera and I can't find a way to change to the other camera.
If I am in the field and have the cameras setup, I need to remote in and check each one to make sure they are capturing correctly. At the moment I can only check in on one and have to trust that the other one is working properly. I am working towards having 4 osmo actions in the field all shooting at the same time and I want to be able to check each one remotely as I am on a construction site and can't always access a camera once it is setup (e.g. on the hook of a crane).
Suggestions:
1. Split screen view of multiple cameras would be so good!
2. In the device connection menu, a preview frame should be provided from each option. I can't tell what camera is what from the random naming convention.
3. Create a favourites device list that lets me swap between cameras.
Thanks!
