JJB*
Flight distance : 12401030 ft
Hi azntastic,
Had a look at your flight and i do not think it was the really wind....
Your first part of the flight easy one, but reaching 927 meters away it looks like you did not know how to fly back to home.
Distance out with no RC input did not really change, so the wind did not blow it further away.
At 3m36 it lost connectiin, an out of control RTH started.
At3m54s connected again ; heading now 133 (was 318 before), so it pointed towards home (HP 127)
Distance out 927, after 7 seconds RTH cancelled. distance 928 meters.
In sport mode (heading to home was good), yaw move to heading 320.
But with no input distance out remains the same, but craft needs power to keep in position. (see pitch and roll angles)
From 4m10 to 4m22 no position change.
Now 100% roll left with craft heading 321, does not bring craft closer to home.
At 4m34 100 pitch forward on heading 333, so craft moves away from home.
At 5m42 distance out 951, at 6m19 distance out 951 meter.
Finally at 8m43 heading towards home, fully forward and flying home.
Distance from 1032 to 788 in Sport mode, but than you stopped with the forward input.
At 9m40 to 9m47 distance 788 - 791, so drifing little backwards.
Again fully forward, distance out reducing to 777.
Bad luck to loose connection, connected again in RTH mode but flightlog ends...
Guess in RTH mode craft did not have the speed to fly home, with 43% it should be possible with less wind.
If you had steer towards home at the end of the outbound leg, in sport mode MM was able to fly home against the wind.
You did loose so time but after that it flew back home, but loosing connection was the killer of your MM.
I count many (11x) disconnects in your flight, some short in time and 2 long enough to force a RTH.
cheers
JJB
