Sigmo
I LIke the OP's idea, too.
Sure, if you've still got contact with the Mini, then of course, you have various options at hand.
But in the case where the Mini has lost contact with the RC, and it goes into RTH, AND it has enough battery left, etc., then why not have it look at ground speed, and if it's "losing the battle" fighting the wind, then increase its airspeed as required to achieve decent ground speed progress on its own. This might not always work, but it's better than just giving up and drifting backwards IF it does have the power to make some good progress. This would not require any heroic amount of programming to achieve. As has been pointed out, the drone already has plenty of information to make this assessment.
If and when you regain contact with the mini, and you know where it is, then you can take control again and try to use the most effective and safe speed, altitude, path, etc., to bring the drone back to you or to a safe (and known) landing location. Even if the drone can't make it back home, at least getting it back into RC range may allow you to get it to a safer landing area and perhaps find it afterwards.
I don't see the point in NOT doing this. People arguing that it will just make ALL mini fliers fly more recklessly are not correct. Does having anti-lock braking, airbags, or seatbelts in your car make you drive more recklessly? OK, maybe don't answer that! ;)
And those imagining that the drone will fly faster and be more of a danger to others forget that this would only kick in if the drone was unable to fly toward home due to wind. The drone doesn't have to achieve a higher ground speed than some limit. It just needs to overcome the wind and achieve SOME ground speed. Just set up a ground speed limit for RTH.
