Error en Sensor Inferior 180016/180030/180031
18951 26 2020-1-20
Janios
Flight distance : 37113 ft
Chile
Buenas a todos,
Ayer me aparecio este error Error en de calibración en el Sensor Inferior, Contactese con DJI, 180016, 180030, 180031, nunca se me ha caido ni golpeado.
Tampoco muestra imagen de la cámara en pantalla.
Intente actualizar el Firmware desde DJI Asistant 2, pero no se arregla el error.
2020-1-20
Paul_IA
Flight distance : 4959019 ft
Google translate is your friend:
Good to everyone,
Yesterday I got this error Error in calibration in the Lower Sensor, Contact DJI, 180016, 180030, 180031, I have never dropped or hit.
It also does not show camera image on the screen.
Try updating the Firmware from DJI Asistant 2, but the error is not fixed.
2020-1-20
InspektorGadjet
Flight distance : 439915 ft
Que telefono estas usando? Hay niebla?
What phone are u using? Is it foggy?
2020-1-20
Janios
Chile
I'm using an Iphone XI.
2020-1-20
Janios
Chile
Here is the error
2020-1-20
InspektorGadjet
Have you calibrated IMU and COMPASS ?
Maybe some of the errors go away after that.
2020-1-20
jonny007
Same as a few weeks ago in https://forum.dji.com/forum.php?mod=viewthread&tid=205364
Users are speaking from "DOA" (dead on arrival). You won't be able to do anything there. Unfortunately, this is a case for a return.
2020-1-20
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for reaching out to DJI Forum. Since you have tried to trouble the issue using the DJI Assistant 2 and the issue still persists. Please contact our DJI Support Team to further diagnose the said issue. Rest assured that our DJI support team will do their best to assists you regarding this matter. Thank you.
2020-1-20
djiuser_cjm2IIN6b8BS
Flight distance : 1621 ft
Peru
Hola, quisiera saber cómo arreglar ese error.
2020-7-3
djiuser_r1DhSGo2C8B7
Flight distance : 95302 ft
Uruguay
InspektorGadjet Posted at 1-20 06:38
Hola. Tengo un spark y me dio ese error. Habia niebla. Sera por la niebla.? Ojala asi sea
2020-9-17
InspektorGadjet
djiuser_r1DhSGo2C8B7 Posted at 9-17 03:09
Si quieres ayuda de la comunidad mjor escribe en inglés, la niebla puede dar errores por falta de vision y condensacion, ademas es peligroso porque a veces no baja, se cree que hay un obstáculo debajo.
2020-12-6
Bleksis
Acabo de comprar el Drone, lo he sacado de la caja, Y ME DA EL MISMO ERROR, que frustrante!! alguien puede ayudarme? He visto que existe el DJI Asistant 2, lo he instalado, pero me sale un mensaje que pone: going to the data upload page will change the dji device status, No se que hacer... vaya compra!
2021-1-30
djiuser_H7XYxP3OhDgk
Costa Rica
Hola! vieras que desarme mi drone que presentaba este error y note que 2 pines  en el ribon cable que conecta los sensores inferiores, estaban desalineados, con mucho cuidado los alinie con una pinza y se soluciono.
En mi caso mi drone tuvo un accidente  y mientras lo abri para revisar puse haber doblado los pines por accidente pense que podia ser la causa (por que antes no presento)
Espero que si alguien ocupa ayuda esto le sirva revisen los pines de ese sensor.
2021-5-2
djiuser_arrceLatf9TP
Brazil
por favor, ¿cómo se resolvió el problema?
2021-5-7
edgaralyu
Mismo problema justo a las dos semanas de caducar el care refresh, que rabia...
Alguien lo ha podido solucionar?
2021-10-25
djiuser_NHTMQRdnquQV
Ecuador
DJI Paladin Posted at 2020-1-20 10:26
I don't know what's wrong with this mavi. Mini se
2022-9-21
DJI Paladin
djiuser_NHTMQRdnquQV Posted at 9-21 05:09
Hi there. Thank you for reaching out and we're sorry if you are having an issue with your unit. Can you please confirm what specific issue did you experience with the unit? Can you please screenshot the error message? Please keep us posted. Thank you.
2022-9-24
FIRPERBOY
Uruguay
compa, has podido dar solucion a esto? me pasó lo mismo luego de usarlo apenas 2 veces...
2022-10-10
FIRPERBOY
Uruguay
DJI!!!  I bought a mavic mini, used, the aircraft worked perfectly until I updated to the latest firmware, so I have a drone that doesn't work, I can't claim, you can't downgrade this model.  What is the solution?  do you plan to put a new firmware version?  Apparently I'm not the only one who had this mishap.  will I have to tether the drone to the roof to see it in the air?  SOLUTIONS PLEASE!!
2022-10-22
Fernagan83
Argentina
Recien saco de la caja un nuevo mini 4 pro y me muestra un error en el sensor inferior. Me comuniqué con el soporte de dji y parece q la única solución es enviarlo a un servicio técnico. Estoy profundamente desepcionado. No lo puedo creer. Pura basura
2023-11-12
DJI Tony
Fernagan83 Posted at 11-12 20:33
Hello there. Sorry about the experience. The Vision system may need to be calibrated after being stored for an extended period. A prompt will appear in DJI Fly, then please tap the prompt and calibration will be performed automatically. Please keep us posted. Have a great day ahead.
2023-11-13
Fernagan83
Argentina
DJI Tony Posted at 11-13 02:12
No encuentro la opción que mencionas. Realicé todas las calibraciones de la nave, el gimbal y el control rc. Tambien actualicé el firmware. Nada pudo solucionar el problema. Podras brindarme algun tutorial?
2023-11-13
DJI Tony
Fernagan83 Posted at 11-13 03:09
Hi. The system will know it needs calibration and will show a prompt that you can tap and the calibration will begin. If it does not show, I'm afraid you indeed need to send it for repair. You can submit a request here: https://repair.dji.com/. We appreciate your patience and understanding.
2023-11-13
djiuser_Q3spyAJBrccg
I got error 180030, 180031 and 180016 on my mavic mini, does anyone know how to solve it please?
2024-8-14
DJI Diana
Flight distance : 2408 ft
djiuser_Q3spyAJBrccg Posted at 8-14 07:53
Hi there,
thank you for reaching out.
We apologize for the inconvenience. Before we further assist you, could you please share the screenshot of the said errors that you received?
Looking forward to your response. Thank you.
2024-8-15
djiuser_9mc6Gc4KISWa
Colombia
Tengo error en sensor visual inferior que hago ????
2024-12-2
DJI Diana
djiuser_9mc6Gc4KISWa Posted at 12-2 04:56
Hi there,
2024-12-2
