Geebax
seafurymike Posted at 1-27 19:47
>>You should always format the SD card in the aircraft using the facility in camera settings of the DJI Go app., not in an external computer.
# I don't see any benefit other than ease when the SD card is inserted into the drone - eXFAT is a ratified industry format and is supported by all major vendors. The drone appends a directory system as part of the writing process which is done automajically. Plus, in my case, the drone didn't see the SD card so trying to format it in the drone was not an option.
Half the people on here would not know what format scheme to choose when formatting the card, but the drone itself always knows exactly which one to choose.
20 Mbps is hardly 'plenty'. And they always quote the maximum rate, the sustained rate can often be a lot lower. The sustained transfer rate is the most important parameter.
"but I want DJI to agree to provide proper support via engineering before I start to make any changes to the Mavic that may put it back into an inoperable state."
To quote The Castle, tell him he's dreaming. 'Engineering' never come on this forum, all you get are the moderators who are not in the least technical and cannot offe any technical advice. You will get better and more accurate advice from the members.
