ShadowDragon81
Mixel11 Posted at 2-3 19:12
I think I have the same problem, or similar. But I'm not sure, because i have just recieved mi dji osmo mobile 3 today...
When I slide the buttom it zooms, but when I stop, it skips to 1 again...
If I zoom using my fingers on the screen it works, but when I use the button it fails...
Sounds different but related.
The zoom on the phone screen works for me too, but as I zoom in using the button on the gimbal, it will zoom at normal speed until it get to around 1.2, then it just jumps to 6. Lately it's been varying around 1.2, but almost always there.
When zooming back out, it will go from 6 to around 3.4 normally, then jump to 1.
It does work fine from the screen, but if i'm moving, that's not an option.
Not to mention any force you use against the gimbal causes the motors to work harder and then you get the problem others have of overheating.
The problem only started occurring after the last software update, so it should be application related, not gimbal related. Yours is slightly different since it just skips back to 1 when you stop zooming, but again, likely a software issue.
