Sorry for the troubles with Ronin-S, please press twice the trigger button to recenter the gimbal, then check the joint angle parameters under APP's Motor Parameter, if any joint angle value is above 1 or the axis arm drifts after the gimbal is re-centered, the joint angle calibration is needed.
1. Push and pull the joystick several times to make sure the joint angle value is less than 1 or the axis arm is in centered position.
2. Press and hold the joint angle in the APP for about 6 seconds to start the joint angle calibration, then click OK.
If the Pan axis is still not centered, please try to reduce the deadband value to see whether it works.
