fans147b0783
Titan DC2 Update outdoor. Started seeing Slow SD again and symptom of screen artifacts or codec. Changed setting to manual record. Start recording prior to flight maybe even before arm. Have made multiple flights 40Mbit/s videos from the Air Unit with the newest firmware. Ran through full batteries. Most videos are more than 4 minutes in length. This quad was BNF no comments on wiring. Settings 16:9, Focus Mode Off, Auto Record Off, Record to Both, Hi Quality Setting, Stock Antenna, No OSD. DJI Transmitter. Still have not formatted card. Not really looking for a way to reproduce the error but it seems like settings are the key so far.
Also noticed if SD Slow Error raises then the video length is only 10-15 seconds long with some audio past that. So, if I dont see an error after 15 seconds that is a good sign the recording session will continue throughout. I have not seen a failure past that time of flight.
