jmtw000
The Phantom 2 Vision and Vision Plus both use the 5.8Ghz range for their controllers and 2.4Ghz for the camera and telemetry. You can't really use another controller with them. Unless you can find a 5.8Ghz one, which I've never seen, or install a 2.4Ghz receiver which would then probably interfere with/get interference from the camera. The regular Phantom 2 uses 2.4Ghz for it's control. So you can use different controllers with it.
As for Naza mode, I think it's mostly personal preference. I've never had the need for it myself.
Having repairs done by DJI does sound like it takes an inordinate amount of time. I've never used it myself though. Most of the parts for the Phantom are available so you can repair things yourself, with one GLARING EXCEPTION. The ribbon cable for the camera on the Vision Plus. For some mysterious reason DJI will not make this part available.
Concerning fly aways, I'm sure some are due to design flaws. But I think the vast majority are pilot error. The only reasons I can think of that might cause a fly away without GPS lock would be if somehow a previous home point is stored in the Phantom, failsafe is triggered, and the Phantom heads off toward the old home point. Or if the pilot screws up without GPS lock or the control signal has interference (unlikely but not impossible) causing the Phantom to fly off, it isn't going to come back. All that said, I regularly fly without GPS lock at my house until I get above the house and hill behind it and can get a good GPS signal. I've never had an issue. |
