Guorium Posted at 2-18 04:27
I told you those ones not responding to stick up had other issues. For example, issues that made the sticks useless? I watched the video you shared long ago. He had ESC error and came to the conclusion that changing props did the trick in a follow-up video. I never had an ESC error ever. I tested for scenarios where stick up can work. Different problem. How many more times do I have to tell you this? You don't have to show up at my post and talk smack about how my testing is not testing YOUR issue. Of course, it does not. It was designed to test a different issue where sticks actually work.
Let me make this real clear.
Your issue: Uncommanded descent with irresponsive mini.
#1 - "Uncommanded descent with irresponsive mini."
#2 - "Uncommanded descent with responsive mini."
Both situations are initiated by same problem? But in first situation an additional problem is causing MM to not respond to pilots Ascend command (Throttle increase). Along with throwing up Error messages (ESC).
Example: Air speed of drone (ground speed + wind speed) in forward direction is causing MM's barometer to give invalid altimter reading as a result slight increase in internal pressure.
In situation #2, MM is responsive to pilots Ascend command.
In situation #1, MM is irresponsive (sluggish?) to pilots Ascend command because of:
a) Original prop blades were not kept paired at factory during manufacturing
b) Defective Blades used during manufacturing of drone vs. blades shipped as spares. c) Blades are wearing out at screw mount points, resulting in blades wobbling up/down or twisting (rotating) under torque.
"a" would not fit with pilot in video's experiences - He was not initially (first weeks of flight) seeing the problem.
"c" would fit with pilot in video saying - ln looking back at first weeks of his MM's flight logs, shows signs of forth coming problem. "b" would also fit, if Defective blades became worse over time.
