A3 pro + Lightbridge 2
1169 1 2020-2-17
kasfruitgmail.com
Dear Forum Members,
I am building custom drone using A3 Pro + Lightbridge 2.
Everything is connected as it should, however I am unable to get Lightbridge 2 powered on.
I don't use any gimble. That means Lightbridge 2 is connected to A3 Pro via only one cable (DBUS II).
A3 Pro works perfectly however, Lightbridge 2 neither power up nor I can connect it to computer using USB cable. I don't see Lightbridge on DJI assistant software as well.
Could you guys please provide any suggestion?
Thank you!
2020-2-17
romaxprodyahoo.com
Did you solve problem with powering LB2? If no I can help you with it.
2020-9-4
