hallmark007
Flight distance : 9827923 ft
Ice_2k Posted at 3-3 02:15
Ok, let's do this. I'll answer each and every one of your questions, then you do the same, ok?
1/ how will atti mode help you with a drone spiraling out of control.
Your answer to #1, in fact the only reason you have given for maintaining an atti switch is TBE, which is caused by interference, and maybe we should hear from jjb what is his experience in this matter and if he can give his reasons why atti switch would yield better outcomes for what it is your looking to counteract.
I have flown drones for over 5 years now with atti switch, I have been here on this forum for almost all that time, and to this day I have never seen a flight log where a drone went into TBE and controller switched to atti mode and saved his drone landing it safely, so none for me so far.
I have watched a video of a guy demonstrating toilet bowl effect by attempting to land his drone on a corrugated roof to show the actual circular motion of the drone, I looked for video but couldn’t find it.
The reason I looked for it was to point out that TBE as most around would see it was not anything as slow or as deliberate as what happens when we see it in an unplanned way.
You say logs don’t show craft going from IMU heading to compass error yaw error and craft going to atti mode, but part of that problem is the log itself.
Just a week or so ago on this forum user came on and told the story of how his drone from launch took this very sharp turn and ended up in the pond.
He gave all information log where he launched and how drone reacted, your friend jjb was first to let him know that his crash was more than likely down to weak gps, he had judged this directly from the log presented.
But the actual flight and how the drone reacted was nothing like weak gps and also no consideration was given for VPS.
Having closely at the crash where the pilot took off from and the direct action the drone took including diving into the water, it was clear something other than weak gps was the cause, and from my point of view from how craft reacted from take off and where launch was I predicted that crash was caused by interference caused by the environment craft was flown in, and dji found this was exactly the reason for the crash.
I mention this because PH logs for mini are very strange and don’t fully resemble what exactly occurred, like no yaw reports, we never see opti mode reported in fact we are completely missing many error reports from logs, so because we don’t see immediately atti mode proceed IMU incorrect heading yaw error doesn’t mean craft wasn’t in atti mode, and I believe if you look at other logs like phantom drone logs you’ll find that they are much better laid out but have had many years to bed down and I’m sure PH will improve reporting of mini over time.
You say I said that if you have compass error that gps is dropped in favor of compass, that’s not what I said I said that if there is conflict between compass and IMU then gps will be dropped in favor of compass and this is what’s reported and seen in all dji drones.
You also say that if you got into TBE your only concern would be to save drone, 1/ do you realize how difficult this is I think you’d get about 6 seconds to find your switch and guide your drone and safely land it.
When I done my commercial license we were told if similar happen at take off think of nothing else only left stick down, so much easier than “oh I’m inTBE WHERES my atti mode switch and the 20 different stick movements you’ll need to make because your drone once you switch will never retain gps.
So without going on about this, I see it simply like this your trying to save drones by putting atti switch on Mavic mini, but when have you seen any drone saved by switching to atti mode manually, I have never seen any dji drone, but maybe you have or jjb has.
I have and fly 3 different drones with atti switch and my experience has been I’ve only ever switched to atti mode to fly in atti mode.
I have seen many over the years crashing in atti mode practicing , I own 4 mavics and I know as we all do not one Mavic was crashed practicing atti mode, I have seen and read of users loosing gps craft going into atti mode for short periods and auto back to gps and safely landed their craft safely.
And concluding on that, maybe both you and jjb can show me all the craft that have been saved by the use of an atti switch, because if this is the case then yes there is some merit in it, but if more drones are going to be lost more accidents going to had and more property damaged as a result of new flyers being ignorant to what atti mode is about are we better off with it or without it, I think that if mini flyers are still not aware of wind at altitude being stronger or using throttle and elevator to position craft in the wind then the last thing they need is atti mode to save them .
