gnirtS
Flight distance : 5712575 ft
AntDX316 Posted at 3-8 05:10
There is no such thing as corner-to-corner sharpness from a one shot with any DJI drone. Even all the way to the max f/stop, in MF w/ DJI RE Goggles on, moving from closest for infinity will show some DOF. Unless you are running f/13 or higher on an expensive lens, you will Not get corner-to-corner sharpness. You will have blur somewhere and some of the spectacular one shot photos from drone aerials are done where that blurry area blends in w/ the texture of the environment. There is no need to argue. This is how it is. You can get away with a pano shot then cropping in, cropping in, and/or blending focus stacked images together.
Again you fail to understand the very basics of photography.
Corner and edge to edge sharpness is NOTHING to do with focus or focus stacking. Its the optical characteristics and imperfections of the lens.
Focus stacking wont have any effect here.
You then go on to mention narrow apertures without understanding that at those sizes, on any smallish sensor diffraction is going to soften your image not make it sharper.
There is no depth of field blurring on anything here over a few feet away. You can work it out with the maths if you don't trust it but the physics itself doesnt lie.
