AlansDronePics
Flight distance : 814751 ft
Guernsey
Geebax Posted at 3-9 13:06
I suspect you would have to get very, very close to the bridge for it to have any effect. IMO most times the aircraft never gets close enough to cause a problem. One way to test this is to use the compass built into your phone. Call up the compass app then see how close you have to get to a steel bridge structure for it to have any effect. When I did this several years ago I had to get extremely close to see any effect.
I was surprised how insensitive the phone system is to magnetic fields.
I use a Samsung J7 dedicated to the drone and an S9+ for other things.
If I type *#0*# as a phone number, it takes me to a smorgasbord of sensor and system values.
The IMU is always churning out values, the Compass is quiet, by comparison. The needle seems to ignore metal close up, although the graph shows a slight blip.
I think it is probably similar to the drone, you need to be up-tight and personal with metal.
Bridges made of iron or steel (not stainless) quickly take on the same magnetic flux of the earth in a very short time. That being the case, I wonder if the orientation matters. It is the same as the earth.
