JJB*
Flight distance : 12225059 ft
hallmark007 Posted at 3-7 10:53
I do disagree and I will move on but hopefully others will explain why your 100% completely wrong, are you saying that when I turn on atti mode on my P4 pro that compass turns off, do you know how ridiculous you sound . In atti mode craft is able to fly in absolute correct direction, I had to do my practical commercial license in atti mode as do all doing their commercial license.
I hope others jump in and confirm .
Hi Hallmark,
You are bit incorrect about ATTI, well not for all models, for DJI models like Spark, MM, MA and guess also for MPz etc your text is incorrect.
Let scrutinize your "let me explain text"; your txt in blue. my comments in red
The best way I can explain this is. If you put your Aircraft on the ground in normal circumstances, start it up, then lift it up and turn it 90 degrees to the right both your compass heading and IMU will both move together 90 degrees and no problems.
If you put your Aircraft on the ground and there is magnetic interference only the heading of your compass will change, your aircraft will still take off. But when it clears magnetic interference compass will then move to correct heading which you would think was great. But No, what happens is IMU is then conflicted and confused because of this sudden movement by compass, so you receive IMU exceptional heading warning, your aircraft cannot deal with data conflict so decides to switch to Atti mode [ yes all correct so far ] dropping gps in favour of compass simply because aircraft can fly without gps but not compass. [ nope, not correct, compass is off becasue in conflict compass/imu! not with GPS
With a compass error, yaw errors, imu errors DJI drones will enter ATTI mode. For a GPS mode DJI drones need 2 signals ; GPS and Drone compass data.
If drone is forced due to errors to enter ATTI it will automatically disable the use of GPS signals. But GPS signals are still received and LAT LON data written in the file.
Check logs where drone is in ATTI and position data is still recorded.
BUT in your explanation text the drone is in ATTI due to a compass/IMU data conflict. This means that in ATTI drone does not use the compass data as well.
So in ATTI drone is height hold by baro sensor and pitch/roll gyro`s ect are use to keep craft level. Ofcouse wind make craft drift away and craft is in full control by the RC sticks
to steer in around. To bring craft back to home : in LOS easier as you can see how to steer in back, not in LOS its hard to know how to steer. This depends how much compass is offset and if this signal isnot used but shown in the app.
GPS signals and compass signals are never in any way linked to each other, so never a conflict between the 2 signals.
BUT DJI drone need both signals for P-GPS mode, if one or both signals are not good enough/error etc >> ATTI mode.
So conclusion : in a forced ATTI mode de to errors compass data is not used.
BTW this is not for DJI models wich can be switched manual into ATTI mode. In this mode compass and gps signals are normal functioning. Even, as i read somewhere, RTH does function in ATTI for models where you can manually switch to ATTI ( but this you know better ofcourse as i have not tested this ; no P4 for me )
cheers
JJB
