thomasnemo.com
Poland
variable_headMinAngle = -30 // head angle in left position
variable_headMaxAngle = 30 // head angle in right position
variable_headStep = 10 // for how much head change rotation angle (scan environment)
variable_defaultHeadPitch = -5 // pitch in 0 position (looking straight)
variable_headUpX = 0 // determine optionally pitch angle for different head position
variable_normalSpeed = 0.2 // speed
variable_lazyLevel = 0 // 0-10 value (Octo is waiting after he finds an obstacle)
variable_senseSightAnimal = 0 // not supported - will try to recognize animal
Code v1.1
- hearingSense
- sightSense
Link
Code v1.0
import random list_Cx = RmList() list_Cy = RmList() list_Cd = RmList() list_collision = RmList() list_senseTouch = RmList() list_senseSight = RmList() list_senseHearing = RmList() pid_Ii = PIDCtrl() variable_scanX = 0 variable_scanDir = 0 variable_isAlive = 0 variable_headMinAngle = 0 variable_headMaxAngle = 0 variable_headStep = 0 variable_headUpX = 0 variable_lookUp = 0 variable_lookUpStep = 0 variable_defaultHeadPitch = 0 variable_dX1 = 0 variable_dY1 = 0 variable_dX2 = 0 variable_dY2 = 0 variable_dV = 0 variable_normalSpeed = 0 variable_lazyLevel = 0 variable_i = 0 variable_isMoving = 0 variable_senseSightAnimal = 0 variable_senseHearingVoice = 0 def user_defined_saveCoord(): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii list_Cx.append(chassis_ctrl.get_position_based_power_on(rm_define.chassis_forward)) list_Cy.append(chassis_ctrl.get_position_based_power_on(rm_define.chassis_translation)) list_Cd.append(chassis_ctrl.get_position_based_power_on(rm_define.chassis_rotate)) def user_defined_checkSenses(): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii if list_senseTouch[1] == 1: list_senseTouch[1] = 0 user_defined_collision() else: if list_senseSight[1] == 1: list_senseSight[1] = 0 if list_senseSight[2] != 3: user_defined_collision() else: pass else: pass def user_defined_brain(): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii user_defined_checkSenses() if variable_isMoving == 1: if variable_scanDir == 1: variable_scanX = variable_scanX + variable_headStep if variable_scanX > 0: if variable_headUpX != 0: gimbal_ctrl.angle_ctrl(variable_scanX, variable_scanX / variable_headUpX) else: gimbal_ctrl.angle_ctrl(variable_scanX, 0) else: if variable_scanX < 0: if variable_headUpX != 0: gimbal_ctrl.angle_ctrl(variable_scanX, abs(variable_scanX) / variable_headUpX) else: gimbal_ctrl.angle_ctrl(variable_scanX, 0) else: gimbal_ctrl.angle_ctrl(0, variable_defaultHeadPitch) else: variable_scanX = variable_scanX + 0 - variable_headStep if variable_scanX < 0: if variable_headUpX != 0: gimbal_ctrl.angle_ctrl(variable_scanX, abs(variable_scanX) / variable_headUpX) else: gimbal_ctrl.angle_ctrl(variable_scanX, 0) else: if variable_scanX > 0: if variable_headUpX != 0: gimbal_ctrl.angle_ctrl(variable_scanX, variable_scanX / variable_headUpX) else: gimbal_ctrl.angle_ctrl(variable_scanX, 0) else: gimbal_ctrl.angle_ctrl(0, variable_defaultHeadPitch) ir_blaster_ctrl.fire_once() ir_blaster_ctrl.fire_once() if variable_scanX == variable_headMaxAngle: variable_scanDir = 2 else: if variable_scanX == variable_headMinAngle: variable_scanDir = 1 def user_defined_life(): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii variable_scanX = 0 variable_scanDir = 1 variable_isMoving = 1 variable_isAlive = 1 chassis_ctrl.move_degree_with_speed(variable_normalSpeed,0) while not variable_isAlive == 0: user_defined_brain() def user_defined_collision(): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii chassis_ctrl.stop() led_ctrl.set_bottom_led(rm_define.armor_bottom_all, 255, 0, 0, rm_define.effect_always_on) user_defined_saveCoord() chassis_ctrl.move_with_distance(180,random.randint(4, 6) / 10) if random.randint(1, 10) <= 9: chassis_ctrl.rotate_with_degree(rm_define.clockwise,random.randint(30, 60)) else: chassis_ctrl.rotate_with_degree(rm_define.anticlockwise,random.randint(30, 60)) led_ctrl.set_bottom_led(rm_define.armor_bottom_all, 255, 255, 255, rm_define.effect_always_on) list_collision.append(armor_ctrl.get_last_hit_index()) gimbal_ctrl.angle_ctrl(variable_scanX, variable_defaultHeadPitch) if random.randint(1, 10) <= variable_lazyLevel: time.sleep(random.randint(5, 20)) chassis_ctrl.move_degree_with_speed(variable_normalSpeed,0) def start(): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii media_ctrl.play_sound(rm_define.media_sound_solmization_1C) led_ctrl.set_bottom_led(rm_define.armor_bottom_all, 255, 255, 255, rm_define.effect_always_on) armor_ctrl.set_hit_sensitivity(10) robot_ctrl.set_mode(rm_define.robot_mode_free) variable_headMinAngle = -30 variable_headMaxAngle = 30 variable_headStep = 10 variable_defaultHeadPitch = -5 variable_headUpX = 0 variable_normalSpeed = 0.2 variable_lazyLevel = 0 list_senseHearing=RmList() list_senseHearing.append(0) list_senseHearing.append(0) list_senseSight=RmList() list_senseSight.append(0) list_senseSight.append(0) variable_senseSightAnimal = 0 list_senseTouch=RmList() list_senseTouch.append(0) list_senseTouch.append(0) chassis_ctrl.enable_stick_overlay() gimbal_ctrl.enable_stick_overlay() gimbal_ctrl.set_rotate_speed(150) gimbal_ctrl.angle_ctrl(0, variable_defaultHeadPitch) user_defined_life() def chassis_impact_detection(msg): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii list_senseTouch[2] = 1 list_senseTouch[1] = 1 def ir_hit_detection_event(msg): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii list_senseSight[2] = 1 list_senseSight[1] = 1 def armor_hit_detection_all(msg): global variable_scanX global variable_scanDir global variable_isAlive global variable_headMinAngle global variable_headMaxAngle global variable_headStep global variable_headUpX global variable_lookUp global variable_lookUpStep global variable_defaultHeadPitch global variable_dX1 global variable_dY1 global variable_dX2 global variable_dY2 global variable_dV global variable_normalSpeed global variable_lazyLevel global variable_i global variable_isMoving global variable_senseSightAnimal global variable_senseHearingVoice global list_Cx global list_Cy global list_Cd global list_collision global list_senseTouch global list_senseSight global list_senseHearing global pid_Ii list_senseTouch[2] = 2 list_senseTouch[1] = 1
