DJI Natalia
djiuser_FCUyNn1rdlRV Posted at 1-15 17:30
My son got his mavic mini stuck on a tree, and upon finally dislodging it the mini fell about 40 feet to the ground. The camera/gimbal popped out and both transmission/flat cable were damaged. I replaced the cables and it all went very easy, but the mini will not turn on. When I push the power button the 4 LED lights showing battery charge light up for a few seconds, but there is no response to the second (start up ascending lights phase) button push. I don’t want to go with the “eenie meenie minee moe” option for deciding what part to try next. Any advice on what might cause this? All of the videos I’ve watched with main board issues show drones that turn on, but display jerky motors or twitchy camera…stuff like that. I also read some posts that said if I change the main board the drone won’t work anyway due to some DJI magic that can only be performed by certified technicians and the like. Is this accurate?
Hi, there.
We are sorry for your inconvenience.
For your problem, it is suggested to send us your drone for a further check.
Here is the link to start a repair case: https://repair.dji.com/repair/in ... ndsite&from=nav
If you have any more questions, please just let us know.
Thank you. |
