JJB*
Flight distance : 12401030 ft
Bloodied_Mini Posted at 4-21 20:42
A few things to add to this thread, JJB have reported that he used the same drone and same props to fly after the incidents and he did not have issues with subsequent flights. This points to possibility this have nothing to do with deformed props due to storage.
The question is, was the props deformed (or the arms deformed) in flight due to stress of wind or maneuvers?
Correct, had a flight yesterday (same props, batterty etc) in wind up and over the limit.
No problem at all. Only once a max power reached message, this at the end of the flight when the battery total volts < 6.6.
In my uncontrolled height drop i found a error in my DAT file, this error (height control fault) exactly at the moment of the height drop.
So i am looking for flightlogs and DAT files of such flights to see if there the same error is present in the flight.
BTWheight variations due to rapid stick moves are more present that in other drones, just a MM 'thing'and not the real problem.BTW
baro height indication changes due to wind the same, easy to check when fly fast few meters above flat ground (in VPS height range).
2 things ; sometimes MM actual ascends, sometimes only the indication indicate higher values that the actual height.
But the real problem is the uncontrolled height drop, and happens afaik only with low but not too battery values.
cheers
JJB
