Having some intermittent issues with my P3 Adv controller (video attached) , when I plug it into the charger it will charge normally to about 75% (3 dots) and then it will just stop charging. And then start charging again after about 10 seconds. This cycle constantly repeats itself, the drone's battery seems to charge without issue, so would the likely culprit be the remote itself? Is this something anyone else has experienced?
Hi UnsyNZ, may I know if the controller can be fully charged if you keep charging it? If no, you may send in the controller for diagnosis and service. If you are located in New Zealand, you can contact the dealer or the recommended repair center for help.
DJI Thor Posted at 4-19 23:33
Hello
Thanks for your reply
Yes I think if given long enough it would fully charge. However given that it is constantly repeating the cycle of charge-not charging-charging this would take a very long time. Do you think the battery is faulty?
