DJI Digital FPV System Release Notes (4/13/2020)
12345
45528 176 2020-4-13
Atomicodex
Flight distance : 1099268 ft
Giammi Posted at 4-13 12:53
You'd better write only when knowing things, otherwise you can create false information.
No, you can't view your custom OSD (i.e. BetaFlight). You can only view the DJI OSD, but it is not recorded on the movie. It is only saved in the .srt file that has to be manually overlaid with dedicated software.
I think that if your FC has a black box you can do an overlay in post.
2020-7-2
Change Agent
Rolled my remaining AU's back to v01.00.04.00 and recording works fine again. The issue with the freezing OSD elements seems more pronounced though. Shake a leg DJI we need v01.00.06.00.
2020-7-4
WeatherB
Change Agent Posted at 7-4 12:54
Exact same behavior for me.
2020-7-4
Xviews
Flight distance : 229255 ft
I think DJI will need a while for the next update, because they also have to do an update for the Caddx Nebula.
But I hope it won't take much longer
2020-7-4
fansa112538d
Dji, I would like, please, to keep the analog video in static when there is weak signal, instead of jumping to the DJI start logo. I'll be waiting for more updates!
2020-7-6
Bezik
Flight distance : 420646 ft
New firmware is out!
2020-7-8
Xviews
Yes its out
Date: 2020.07.08
Air Unit Firmware: v01.00.06.00
Goggles Firmware: v01.00.06.00
https://dl.djicdn.com/downloads/DJI_Digital_FPV_System/20200708/DJI_Digital_FPV_System_Release_Notes_EN.pdf
2020-7-8
Bezik
Xviews Posted at 7-8 11:30
Yes its out
Date: 2020.07.08
Controller updated too
2020-7-8
Change Agent
Flashed new v01.00.06.00 firmware and as soon as I get a day when it's not raining I will see if they fixed the record issues. So far though the 50Mbps mode works and looks better just placing it on the porch and switching between modes.
2020-7-8
Hummingbird.UAV
Flight distance : 27489951 ft
Change Agent Posted at 7-8 14:00
So I installed the .06 updates, however when setting the Transmission the 3rd menu item "bitrate" is greyed out.  I believe this should work in Canada.  Is there something I need to set first?
2020-7-8
Kreeze
Hummingbird.UAV Posted at 7-8 15:33
canada isn't governed by the FCC so you won't be getting 50mbps without changing your region (could be wrong but that's my working theory)
2020-7-8
Hummingbird.UAV
Kreeze Posted at 7-8 16:11
And how would one go about changing the region?  I've connected my NORD VPN to a US site and then wanted to reinstall the firmware but the DJI Assist software does not work through the VPN, "network error"
UPDATE:  Reinstalled Air Unit firmware now 50mbps is working.
2020-7-9
foot
I updated to version 6 update but i canot select the 25mbs option to cjange it to the 50mbs ootion? Its strange cause the option lights up when i first enter the drop down menu but it imediately turns grey and is unselectable.....any ideas? I updated twice same issue both times
2020-7-15
Change Agent
Nearly works 100%. The new 50Mbps mode doubles range to 13KM which is awesome. No more chopping of videos and remaining corruption was solved by updating video codecs. The lagging/freezing OSD issue is still present but catches up after about 10 seconds when it happens.
Now for v01.00.07.00 we need:
Lagging/freezing OSD issue gone totally
Live audio
All OSD elements especially GPS recorded in SRT file
Full OSD playback on goggles
Full Betaflight OSD elements available as especially "warnings" is needed
Improved audio bitrate 160Kbps or greater (vs current 96Kbps)
Improved video bitrate 50Mbps or greater (vs current 40Mbps)
Option to have the Air unit stretch to 16:9 when recording to save post processing
Air unit temperature OSD element
User configurable low battery warning voltage
Selectable automatic EV+ feature for when transitioning from light to dark and vice versa to prevent whiteout and blackout
Addendum fanciful suggestions:
Non GPS distance from home using radio signal range finding
Live stabilisation at slightly lower resolution
Software radio analogue reception
Full spectral analysis menu with auto recommended channel selection feature
Auto channel switching if analogue video detected on same channel during or before flight with alert message
Lower bitrate, higher range (26KM) 2.4Ghz mode available after installation of appropriate antennas with perhaps option to have both 5.8 and 2.4 modes using one antenna of each type switching as range ends
2020-7-15
djiuser_RgeukNVYJcsa
Need live audio +1
2020-10-28
fansa362a1c8
Flight distance : 247533 ft
By when a new FW version?
2020-11-13
Rickyboy92371
om.antonFPV Posted at 2020-4-17 07:48
I just updated the DJI air unit and Goggles to the latest version (v01.00.05.00) but I have some problems with GPS OSD. I have activate gps osd at betaflight for the home arrow, coordinates and location of the home point.
But when I try to fly it today, home arrow and home point location do not work, i saw GPS sat and coordinates (log/lat) working.
Yep...I just finished an FPV setup with the DJI Digital FPV System working with a fixed wing FC the Mateksys    F765-wing. Same problem your having with the OSD in that a single bar displays where the direction to home arrow is  supposed to be. Also, only the side bars for the artificial horizon exist...basically unusable.
The setup was done in INAV and all looked good until you view in the DJI goggles. My feeling is DJI has restricted what can be available in the OSD regardless of how it's set up.
2021-3-10
12345
