fansd002d3ee
I fired up thte drone, and had n image with diagonal lines through it - thick dark lines alternating with lines that had digital "noise." From what I have read this is a ribbon cable problem.
So I tied to seat all the connections - didn;t take it apart, just did a visual check and firmly seated the connections I can see.
Fired it up again and the screen is dark - "NO IMAGE TRANSMISSION."
So I figure I killed the ribbon cable. I see others have replaced the able. How hard is it to replace? Is it something a novice can do? If it matters I am NOT a techie but have installed memory cards etc..., in my computers.
Thanks in advance...
