FPV remote keeps beeping
4946 6 2020-4-15
prtm
Flight distance : 370217 ft
My FPV Remote controller keeps beeping forever.
After turning it on, the status indicator LED turns red. Then after a few seconds, it starts beeping. I can't find what it means to have a red LED in the manualat all.
I've gone through maybe all of the "FPV controller beeping" threads in this forum and can confirm
  • My battery is way above 10%
  • Moving the controller doesn't make any difference
Some thread mentioned about calibrating but I don't know how do you calibrate it (I'm unable to bing the controller with the Air Unit).
Here's a video a captured https://photos.app.goo.gl/VdBsmZwCZu9wXTx69
2020-4-15
whoistfd
Mine just did this as well, so I feel your pain l.  I needed to connect the controller to my ipad / phone and start the GOAPP.  Drone off, then in the upper-right there are 3 dots, that is where you will find the options for the controller and calibration.  hope this helps
2020-4-16
Tom_A
Flight distance : 899951 ft
The throttle is up. You didn’t even attempt to move the throttle down during the video. It’s a safety feature that exists on every remote I have used for FPV.. OpenTX remotes will do something similar if the switches do not match their initial positions although it’s configurable.All remotes will refuse to send a signal until you lower the throttle after turning on.
2020-4-16
prtm
Tom_A Posted at 4-16 07:05
Thanks for the help Tom. This make sense.
I read on another thread suggesting to *move* the throttle, but I didn't understand it meant I should put it down (and yes, I forgot to capture the moving the throttle part).
2020-4-16
djiuser_4M5LcgXHZlnX
Additional note:
I am using DJI FPV and experienced the same issue. Out of the box the remote was physically Mode 1 (Throttle on the right) but software was Mode 2.
Therefore, throttle warning was always going to be sounding, which is confusing during pairing/linking process imo.
Resolution: Once pairing process was done, in goggles>settings>remote>mode and adjust to suit.
2020-10-16
fans6c4a33dd
Flight distance : 1612835 ft
Hello,
I have a same pb with my remote controller without issue.
I used to fly in mode 2 with my FPV drones.
From few days without explanation,my two quads are bind, but the remote controller keep beeping... Unable to arm etc..
The only way to avoid that is to switch to mode 1...
How can I fix that , each time I switch in mode 2 the problem remain...
Thanks a lot.
Baptiste
2021-1-2
mc54
Flight distance : 1030 ft
Try calibrating your sticks?
2021-1-3
