SimplePanda
Flight distance : 1719062 ft
If DJI is selling an S900 + A2 + Zenmuse bundle, you also need:
a) Batteries with appropriate connectors (XT150), or batteries + connectors and a soldering iron. 10,000 mah 6S packs are a good starting point. The bigger the better within weight limits though.
b) A transmitter, such as a Futaba or Spektrum. No, the P3 controller won't work.
c) A Lightbridge unit. You can also use alternative / competitive units but the Lightbridge is great and works perfectly with DJI gear (has a built in OSD, etc).
d) An iPad, Android tablet, or HDMI display for monitoring.
e) The camera.
f) The correct lens. Zenmuse gimbals are designed for specific lenses only. For the A7x, it's the Sony FE 35 mm f2.8 ZA.
g) Either a good dealer who can assemble, configure and train you OR the time and willingness to do this yourself. You'll be scratch programming your transmitter unit at the very least and this includes basic flight control (flight modes, failsafe, IOC, etc) as well as gimbal / camera controls (gimbal pitch, shutter, etc). Note that with a big Zenmuse if you want really fine gimbal control (full 3 axis movement) you'll need two transmitters - one for the pilot and one for the gimbal operator.
